Old 12-21-2006, 04:28 AM
lbnaz lbnaz is offline
Yenko Premier Member
Default 69 Camaro Z/28
This is for a 69 Camaro Z/28 non RS. Its a 1B X33 car with 711 int and 10B color. There's X3 on the passenger rear seat back area. Clean AZ title. Original numbers matching born with vin on the block 302 short block that is std bore with new GM pistons and std/std 1178 crank NOS 140 cam. Numbers matching original M20 with the vin also, and the original 12 bolt 373 posi rearend. Motor and trans are out of the car. Its a no tach, no console, no guages, flat hood, no spoiler car. The car is a project car that I have been collecting parts for 4 years. I have over 7k worth of NOS parts. Its a whole page on a legal pad plus alot of good used parts for it. Plus I just bought 3k worth of stuff from Heartbeat. There has been one rust repair made on the drivers floor other than that its rust free. NOW FOR THE BAD. There is a ton of good with the car and one major bad. Its a 1B Jan 69 car that someone (prior owner) replaced the cowl tag with another real tag (same date 1B) to change the color from gold to black. Tag is off the car with correct rivets. I'll be around if you guys coming out for the auctions want to see it. Raising funds for another car. I'm in Tucson which is an hour and a half south. The price is 27500. Thanks, Larry. 520-349-2337
