Old 12-15-2006, 07:07 AM
1969camarors427's Avatar
Default 69 Rally Sport original headlight washer lines
I have original GM 69 camaro rally sport headlight washer lines which have the original gm fittings on them. The hoses are the ribbed type. These came of a low mileage car we restored. These ones go under the header panel to each headlight washer jet and also has the original T fitting which is quite a bit larger diameter that you get in the repro kits. I also have a few GM plastic fittings from the rally sport vacuum hoses, one filter and one valve used, this is the metal one that goes from one into two hoses. can email picture if you like. 50.00 shipped anywhere in U.S. or canada.
Old 12-15-2006, 07:57 PM
Default Re: 69 Rally Sport original headlight washer lines
George always has good stuff.
Old 12-15-2006, 08:23 PM
KNAPPY KNAPPY is offline
Geoege you have a PM
Steve
67 Z-28
69 COPO Camaro
