Old 12-13-2006, 05:59 AM
jasonL78 jasonL78 is offline
Default 68 Nova tach problem.
Over the summer my tach started to stick around 3000 rpm. not all the time. When the car was off I could tap the speedometer lense and the needle would fall back down in place. By September it was stuck on 3k. So tonight I pulled my dash apart to see if it is stuck and it was. It is almost like the dial has a flat spot on it. It catches around 3k. My question is does anyone know a good tach restoration place I can call to ask them about the problem and maybe get a quote on what it will cost to have it repaired. The tach still does work.
Thanks Jason
