Old 12-12-2006, 01:14 AM
jasonL78 jasonL78 is offline
Default 396 3935440 block help
Can you tell if a 396 with the casting 3935440 is a 2 bolt or 4 bolt main. Besides the main caps is there any cosmetic difference.
Attachments - The Supercar Registry 239438-4-bult454005.jpg 239437-CBB002.jpg
Old 12-12-2006, 01:16 AM
enio45 enio45 is offline
Default Re: 396 3935440 block help
i thought the 4 bolt had the oil galley drilled out on the side of the block....recall this somewhere when i was seaching for my block.
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 12-12-2006, 01:18 AM
double holes in side above filter.
Jake is my grandson!!
Old 12-12-2006, 02:41 AM
bertfam bertfam is offline
Jason,
2 Bolt Main:
4 Bolt Main:
Ed
Ed Bertrand
1968 RS/SS L-89
396/375 Convertible
CRG Member
Old 12-12-2006, 06:41 AM
Thank you very much. I got a complete 68 396 with the chevelle I just bought and I just wanted to know if it was a 2 bolt or 4 bolt main without moving the oil pan. Thanks again
Old 12-12-2006, 07:31 AM
No problems Jason. So which one did it turn out to be? Two or Four?
Ed
Ed Bertrand
1968 RS/SS L-89
396/375 Convertible
CRG Member
Old 12-12-2006, 09:45 AM
How do you explain the fact that I have two 4-bolt main blocks with the small "oil holes" ?
This pic is from my late -69 4-bolt #512 block.
Anders Stålklint.
Old 12-12-2006, 09:47 AM
And this one is from my 1990 marine 454 4-bolt #286 block.
Anders Stålklint.
Old 12-12-2006, 05:36 PM
Mine ended up having the small hole so I guess it must be a 2 bolt main block. It does have the 2 step oil pan on it. Would the 325hp motor have a windage tray! I will double check it when I get time. I have been looking for a April or May 440 4 bolt block for my 68 L78 nova. The one I just got is a E-18-8 block.The motor I have in the nova now is a 2 bolt main out of a 68 4 speed 350hp chevelle. I want to build a correct L78 motor for my nova in the future. If this block I have would have worked then I was going to use it. I thought the only difference might be the main caps. So I guess the search continues and the motor will most likely go into the 67 chevelle.
Old 12-12-2006, 08:38 PM
How do you explain the fact that I have two 4-bolt main blocks with the small "oil holes"?
I can't
Ed
Ed Bertrand
1968 RS/SS L-89
396/375 Convertible
CRG Member
