Old 12-11-2006, 08:21 AM
Default Dixco Tach - Questions
Hey Guys. I am looking to purchase this Dixco tach. I have a couple of questions.
What is the model number of this tach?
What year did the tach come out? Or Did it come out Early 70's or Late 70's?
Also I know it is a 4 wire tach. Could anyone tell me what the 4 wires connect to?
Thanks very much,
-Dave
Old 12-12-2006, 05:21 AM
Plowman's Avatar
Plowman Plowman is offline
Default Re: Dixco Tach - Questions
Correct me if I'm forgetting which color wires this tach had. From memory four wires being; black (- ground), red (+12v keyed), yellow (+12v switched from dash lights; street racers typically wired this in with the red) and green (trigger - side of coil).
That tach will only work on a points distributor. You'll need the MSD adapter if you're running a CD ignition.
Old 12-12-2006, 05:36 AM
Sounds correct to me on the wire hook up.
Old 12-12-2006, 05:50 AM
Ok Great. Any one know what Model Number this tach is? Or when it originally came out?
Best Regards,
-Dave
Old 12-12-2006, 05:59 AM
ORIGLS6 ORIGLS6 is offline
See if this helps.
www.musclecartachs.com
Old 12-12-2006, 06:08 AM
That's a good web site to have book-marked.
Thanks for sharing.
Any help is appreciated.
-Dave
