Old 12-06-2006, 05:27 AM
sztuty sztuty is offline
Default L 78 rebuild
Dear Gurus
In the process of rebuilding my 1968 396
The motor is in great shape, stock bore, etc
M22 tranny, 373 12 bolt, etc
I am thinking I want to step up the cam a bit
My Nova is a true L78 car, all numbers match etc
Want to have fun and protect its value
Any advice/ opinions would be great
Ty
Old 12-06-2006, 03:50 PM
Default Re: L 78 rebuild
If you are going to keep it original with stock manifolds I would stay with the L-78 Solid cam from Crane. It sounds good and works well with stock manifolds. With headers, I would step up to one of the solid grinds from Comp Cams possibly an extreme energy version with 230 to 240 dergrees @ .050 and .540 to .560 lift. Dont forget a good 3 angle valve job on the heads while you are in there. For an L-78 car, you gotta have that solid lifter "rattle".
Paul
Old 12-06-2006, 08:06 PM
Chevy454 Chevy454 is offline
The blueprint cam from GM/Crane is the one to buy...there are lots of other places to look for power before that cam starts holding you back...
Old 12-07-2006, 01:26 AM
Thamks
I appreciate everyones thoughts
I have always been into small blocks, I want to do it right the first time
Ty
Old 12-07-2006, 01:41 AM
That GM/Crane cam would be a monster with headers also...a local truck puller here ran a spec LS6 in the modified stock(?) class, with large tube headers, and that thing was a monster...he's since turned one of his dated LS6s into an LS7, and has successfully ran that combo for several years...
Old 12-07-2006, 01:46 AM
What are you looking to do with this car? You're asking about a cam here, a firing order swap in another thread, but mention you're sticking with the original block and other original parts...?
By sticking with the bone stock original parts and keeping the compression at a safe 10:1 you could easily see 350-375hp at the wheels...step up the compression a bit and 400+ at the wheels would be a no brainer.
Old 12-07-2006, 01:47 AM
Rob
Are you talking about the direct L78 replacement cam that Crane offers?
That is what the machinist wants me to run, and I have the tendency to go the next step up
Ty
Old 12-07-2006, 01:24 AM
Thanks for the info
I am running Hookers, and will go to the step up
Appreciate the specs
Ty
