Old 12-05-2006, 12:44 AM
Default Engine Rebuilding
When rebuilding a 427 is 65 over rebore too much? Usually I was told 60 is max, any thoughts?
Old 12-05-2006, 02:01 AM
jeff morocco jeff morocco is offline
Default Re: Engine Rebuilding
i went .125 over in one of my race motors.....the only problem with that is if you have something go wrong....its junk. no room to fix!!!
Old 12-05-2006, 02:22 AM
427king 427king is offline
Yenko Paid Member
060 is the max if you are building a newer motor. The early vintage 427 blocks will take that bore size with no issues at all
Old 12-05-2006, 03:05 AM
ANDY M's Avatar
ANDY M ANDY M is offline
My motor is .100 over. Runs fine with a 160 thermostat. Like Jeff said, drive careful. The powertrain warranty is in your wallet.
COPO 9561/9737 M40 X11D80
13.37 @ 105.50 on pump gas,drove it to NATL TRAILS and back [email protected] SCR22
Old 12-05-2006, 06:38 PM
SMGCO SMGCO is offline
You need to sonic test the block to determine the actual remaining cylinder wall thickness then you can make the call.
Old 12-05-2006, 07:25 PM
Chevy454 Chevy454 is offline
A sonic test would be good insurance, but if it's an older/original 427 block then you should be golden...I've heard several folks going to .100 or better on the older stuff...but, if it's gonna be tight, then sleeve it and you'll be better off for it all around!
Old 12-05-2006, 10:50 PM
COPO427 COPO427 is offline
You could sleeve it if the block is important enough to keep for #'s sake.
1970 Norwood Z28 M22, 3.73, Z21, Z87, TR 725
Old 12-06-2006, 12:26 AM
That's the kicker, the motor and the car are restored fresh.
Old 12-06-2006, 05:05 AM
indyjps indyjps is offline
i'd bore it and drive gently, if you want to run it hard swap a new block in and keep the orig block on the stand.
