Old 11-27-2006, 08:53 PM
JHS JHS is offline
Default '70 LS5 EL CAMINO - VALUE??
Not sure if you guys consider a LS5 El Camino a muscle car but I need help in determining a value for the following:
1970 LS5 El Camino, bonni beige/black bench, TH400, 3.31 posi, a/c, ps, pb, am/fm, restored, POP, 2 build sheets, copies of owner titles back to new. Factory original, #'s matching drive train. Things not correc: hooker headers, ss exhaust, valve covers, radiator, shocks. Car runs and drives great and everything works.
'70 L78 NOVA SS
'77 Bronco
Old 11-27-2006, 10:04 PM
SS4Real's Avatar
SS4Real SS4Real is offline
Default Re: '70 LS5 EL CAMINO - VALUE??
A few more details will most likely give you a more accurate estimate. Is the car code 50 Gobi Beige? A few more details regarding the restoration would also help such as frame off or not......drivetrain components rebuilt or not....pictures would also be help with an estimate of value due to the level of restoration.
Jim
Old 11-27-2006, 10:43 PM
JHS JHS is offline
Not sure if body-off resto., new cam was installed per receipts so assume engine was freshened up, has only approx. 77K mi. & is code 50 paint. Here are some pics:
'70 L78 NOVA SS
'77 Bronco
Old 11-27-2006, 10:57 PM
JHS JHS is offline
One more note: the car currently has a square port alum. intake and Holley 4 bbl; I do have the original cast iron intake, Rochester 4MV carb. and fuel pump. (for those ready to pounce on the engine pic )
'70 L78 NOVA SS
'77 Bronco
Old 11-27-2006, 11:07 PM
Late BrakeU2 Late BrakeU2 is offline
Not sure if you're looking to sell or purchase,but around mid upper 20's in this market maybe?? (4spd ZL2 truck perhaps 2k more)People either love or hate Elky's,if you dig them they are a great value imo
Old 11-27-2006, 11:12 PM
TimG TimG is offline
EL COOL..........
Old 11-28-2006, 12:32 AM
bigchevydaddy bigchevydaddy is offline
SS El Caminos represent an outstanding value compared to SS Chevelles, usually 1/3 to 1/2 the price, including LS-6s and L-78s.
IMHO, you can usually pick up a nice one for much less than it cost to restore it.
Good luck, BCD.
Old 11-28-2006, 03:09 AM
I'm a sucker for Whiteline tires on Gobi Beige.
Add a replacement master cylinder,1971 License plate,remove those plastic cowl grates,missing TCS,wrong W/S washer pump,no radiator cooling label and the underside of the hood incorrectly painted body color to the incorrect list.
All easy fixes.
Kudos to the restorer for including the correct CHEVROLET grille emblem,and not making the common mistake of putting on CHEVELLE.
I'd value it as it sits now at $28-35K,w/o seeing it in person.
I personally would like to own this Elco if you pass on it.
