Old 11-08-2006, 10:17 PM
Default 1966 Chevelle
-------Saw what appears to be a very nice 66 Chevelle drop-top on E-bay (#230047471680) and wonder what you guys think??? And what makes a 66 360hp different from a 67 350hp???
-------Im as aware as all of us what restos cost and I dont doubt that there has been goodly amounts of cash thrown at this ride but whats the car worth???
-------Also, would the top of the doorpanels have been black as is pictured or white when the car was new???
-------Thanks for your thoughts......Bill S
Old 11-08-2006, 10:25 PM
GM-26's Avatar
GM-26 GM-26 is offline
Default Re: 1966 Chevelle
Recently, there was some discussion about this Chevelle.
Nick...
Old 11-08-2006, 10:44 PM
-----Thanks, Nick... Still would like to get info on questions though.......Bill S
Old 11-09-2006, 12:23 AM
Cast iron holley intake and carb on the 66. Q-jet and iron q-jet intake on the 67. The true 360 hp most were 4-bolt blocks. They used the 962 block for both 360 & 375 hp Chevelles in 66. Also open air cleaner on the 66 not sure on the 67 Chevelle. The 66 961 block was for the 2-bolt motors. The 67 used a 406 block for both the 375 & 350 hp one was 4-bolt & the other 2-bolt. Hope this helps.
Jake is my grandson!!
Old 11-09-2006, 04:57 AM
Kim,,, Thanks for the comeback. I have a bit of a problem however as I bought a 67 396/350 Chevelle new and it had a single feeder Holley on it. I remember other 67s with 325s having quadrajets though........Bill S
Old 11-09-2006, 05:49 AM
VintageMusclecar's Avatar
The `67 Chevelle 325 horsepower 396 used a Quadrajet carb and a single snorkle air cleaner, and the 350 horsepower version used a Holley carb with the open element air cleaner.
Odd that they would use a larger carburetor (advertised 750 cfm) on the 325 HP engine than they did the 350HP engine (advertised 585 cfm), then proceed to choke the larger carb with the more restrictive air cleaner and give the smaller carb the better air cleaner.
Silly engineers.
Eric
Old 11-09-2006, 07:10 AM
MYSTERYCHEVELLE MYSTERYCHEVELLE is offline
My reply was listed in that above mentioned discussion and still stands for anyone serious about the car.
http://hometown.aol.com/mysterychevele/page1.html
Old 11-09-2006, 07:16 AM
Same problem you have for the 350 hp L-79 66&67 nova 585 cfm in stock & super/stock they were DOGS because of the carb.
Old 11-09-2006, 07:21 AM
Bill you are right my point was about the difference in the block.I didn't explain that. Kim
Old 11-09-2006, 07:23 AM
The 275 & 250 hp 327 will kick a$$ on the 327-350 hp in any class today!!!
