Old 11-02-2006, 02:13 AM
dwwchevellen dwwchevellen is offline
Default ls6 heads
A freind of mine has a set of big block heads,cast numbers 3964291. are these ls6 454 heads? If so what application,he believes the valves are 2.25 and 1.88, closed chamber. if so what is the chamber cc and intake runner cc?
Old 11-02-2006, 03:09 AM
jfkheat jfkheat is offline
Default Re: ls6 heads
3964291 1969-70 396/402 375 L-78, Intake Port 325cc
427 425, 435 L-71/L-72
454 450 LS-6,
Closed 108.0cc
I beleive the valves should be 2.19 and 1.88. Chevy didn't use 2.25 valves in any heads.
James
1968 Beaumont SD396
Old 11-02-2006, 03:37 AM
Good deal James ,I think Im going to try and talk him out of these heads and use them on my gen v 454 Im putting in my 70 chevelle SS( reproduction ls6454 4 spd ) car. Thanks a lot for the great info.
David.
Old 11-02-2006, 03:46 AM
Chevy454 Chevy454 is offline
Can you put Gen IV heads on a Gen 5? I thought there were coolant passage changes on the Gen V's? Also, no fuel pump boss on a Gen V...
Old 11-02-2006, 04:17 AM
I think you can use a diff head gasket set up on one of those combos and make it work ....have to check one of GMPP dealer's sites to be sure.
wilma
Old 11-02-2006, 05:39 AM
Yea, please check on that I'd hate to make a deal with him and not be able to use them,Im running an edelbrock two four set up on the gen v so an electric fuel pump is needed.
under the hood two fours, but if the ls6 heads will not work then i will go with edelbrok rpm heads.
Old 11-03-2006, 12:17 AM
bigchevydaddy bigchevydaddy is offline
Be sure and check the exhaust valve sizes. My 291s had 2.19 and 1.72 valves.
BCD
Old 11-03-2006, 01:20 AM
VintageMusclecar's Avatar
I have a set of early 1970 291's that have 2.19-1.72 valves as well.
I've been told, but I have yet to verify, that the L78 engines got the heads with 1.72 valves, and only the true LS6 engines got the heads with 1.88 valves.
Can anyone confirm this?
Eric
Old 11-03-2006, 05:35 AM
We did measure these valves and the exhaust measure 1.88 and intake measure 2.19 , they date dec 7,1969.I had mentioned earlier that I thought the intake was 2.25 but I had a senior moment I guess, no punt intended.
David
Old 11-03-2006, 06:26 PM
FYI found info in my yearone chevelle book, mark IV cylinder heads will not work on gen V block as well as the crank, balancer ,flexplate or flywheel however will work on genVI block due to chevrolet changed back to prev. coolant passage design.Iguess Ill be purchasing some edelbrock heads after all.
