Old 10-31-2006, 10:47 PM
Guest
Posts: n/a
Default Garage Lifts
Having trouble locating a previous post about garage lifts. Can anyone help?
Old 10-31-2006, 10:57 PM
J_D J_D is offline
Send a message via ICQ to J_D
Default Re: Garage Lifts
https://www.yenko.net/ubbthreads/show.../page/5#205979
J.D. Le Blanc
1997 30th Anniversary Camaro SS #742/2091
2001 Phase I Dale Earnhardt Intimidator SS Camaro #68
2002 Phase II Camaro ZL-1 Supercar #17
2010 Silverado LT 4X4 Crew Cab 6.2 liter
2011 Tahoe LS 4X4 Sport Utility 5.3 liter
Old 10-31-2006, 11:14 PM
Guest
Posts: n/a
WOW that was quick, thanks J D
Old 11-01-2006, 12:50 AM
Guest
Posts: n/a
J D, Beautiful home and shop.............you might want to raise the blades on your mower your scalping the lawn.
Old 11-01-2006, 02:40 AM
69RSZ 69RSZ is offline
I( have Bend-Pak made in USA and had them for 4 yrs now no problems,locks on all 4 posts and can lower all the way down without worrying about any cable damage.see pics
Ron C.
67 RSZ/28
67 Z/28
71 SS LS5 chevelle
Old 11-01-2006, 02:41 AM
another
Ron C.
67 RSZ/28
67 Z/28
71 SS LS5 chevelle
Old 11-01-2006, 03:01 AM
kwhizz kwhizz is offline
Just for Safety concerns, in your first picture you show the Stop Arm not yet engaged in the Stop Notch....you should raise the unit a little higher until the Stop Arm snaps into the Notch.....then lower the lift until the load is now on the stop blocks.....right now the load is on the Cables and hydraulic system.......if one of the corner cables gave away right now, the unit would cant down on one position and the possibility exists the the Stop could miss the stop surface and you would have a teetering mess on your hands.......the construction of your lift is exactly the same as mine with the cable problems........Beware
Ken
Old 11-01-2006, 03:51 AM
You are correct that the lock wasnt engaged but I have since then raised it up.i usally let the lift rest on the locks.I havent had any problems with the cables not lineing up.everything works ok.
Ron C.
67 RSZ/28
67 Z/28
71 SS LS5 chevelle
Old 11-01-2006, 08:01 AM
J_D J_D is offline
Actually..............I wanted to do the whole thing in concrete and epoxy it green....... but she thought I was and said
J.D. Le Blanc
Old 11-01-2006, 08:08 AM
ORIGLS6 ORIGLS6 is offline
"but she thought I was "
Very perceptive, that Nancy!
