Old 10-20-2006, 07:31 AM
Pacecarjeff's Avatar
Pacecarjeff Pacecarjeff is offline
Default Original Horn Relays
Need to clear out some of these Delco Remy Horn relays.
824's - $75
862's - $100
890's - $125
882's - $45
889's - $75
837's - $175
Or make me an offer ???
Other part numbers available.
I will clean these up so they look beautiful.
I test each one, and I guarentee that they will work exactly as they should.
Buzzer function will work where applicable.
Old 10-24-2006, 05:47 AM
Default Re: Original Horn Relays
Cleaned up - They will be this nice or better - Guarenteed.
Old 10-26-2006, 02:27 AM
837's are gone. Only had a few of those.
Everyone always wants those 66/67 ones fast.
Free shipping to Forum members.
Old 10-26-2006, 07:26 PM
What did you clean them up with? I have an NOS one on my car, but it looks asss
Old 10-27-2006, 12:23 AM
I use a dremel tool on the underside, making sure to get all the nooks and crannies.
CAREFULL - Don't burn up the plastic.
Then I use my "Very fine" wire wheel to slowly remove all the years of crud from the cover.
Unless they are rusted or pitted, they usually turn out pretty good.
If you want them to be shinny...
(I don't, I like them dull Zinc)...use a little aluminum wheel polish.
Then, I use soap and water with a Q-tip for the plastic.
I test it first before the cleaning, cause it if they are bad, they are trash - You can try cleaning the points, sometimes that helps get them started.
For a NOS one just use "00" steel wool.
Old 10-27-2006, 01:17 AM
They look real nice. Very original.
Old 10-30-2006, 08:35 PM
A few have asked how I test the relay with buzzer feature.
I use this little "home made" testing device.
This fancy machine tests Horn relays, flashers, and A/C relays.
