Old 09-28-2006, 10:05 PM
47Hammer's Avatar
47Hammer 47Hammer is offline
Default Need help w/Block casting #'s
These numbers are on the rear of the block and i'm not sure what they stand for, any thoughts?
Thanks for any help.
Old 09-28-2006, 10:14 PM
Default Re: Need help w/Block casting #'s
3970010 - Block Casting Number (2 or 4 bolt design 4" bore, 302 or 350 usage, late 69 thru 70's)
I 23 70 - Casting Date Code (Sep 23rd 1970 I think)
Paul
Old 09-28-2006, 10:18 PM
47Hammer's Avatar
If that's correct the block in my car is not the right date because the P-O-P reads V0323CTB.
Old 09-28-2006, 10:45 PM
The 010 block is correct, and the location of the date code is correct as well. I'm not sure it's decoded as Sept of '70 though, wouldn't that date be for a '71Z - assuming this block is the original block? The POP lists the engine assy date, not the cast date.
Old 09-28-2006, 10:52 PM
47Hammer's Avatar
The trim tag shows 04A build date.
Old 09-29-2006, 04:29 AM
I think that's the letter B,not the letter I.
Which would all make sense.
Block cast B-(February) 23rd,1970.
LT-1 Engine assembled at Flint 3-(March) 23rd,1970.
Z/28 Camaro w/4spd assembled 4-(April),A-(1st week),1970 at Van Nuys plant.
Old 09-29-2006, 05:21 AM
47Hammer's Avatar
I think your right about the "B" and when I blow it up real big it looks liks another letter and B does make sense. I now believe this car has the original motor in it. What do you guys think?
Old 09-30-2006, 02:49 AM
47Hammer's Avatar
I cleaned it up a bit. Looks like a B or D ?
Old 09-30-2006, 08:36 AM
Jonesy's Avatar
Jonesy Jonesy is offline
To me, it looks like someone ground off the letter and the end number.
Old 10-01-2006, 06:37 AM
L78steve L78steve is offline
Check the pad in front of #2 cyl.behind alternator to solve your mystery.
