Old 09-18-2006, 12:22 AM
Bigblockhappy Bigblockhappy is offline
Default LS6 Fuel Pump
I just bought a new AC Delco fuel pump for my LS6 Chevelle , part # is 6470424, it doesn't have that deep of a fuel bowl, did I get the correct one?
Louis
1970 Ls6 Chevelle
Old 09-18-2006, 01:21 AM
Default Re: LS6 Fuel Pump
It depends.That's an AC #40727 pump,and early built LS-6's did receive them.
To be certain,look in box #33 if you have your buildsheet.
If it shows #768,short for AC #40768,then it received the higher volume GM #6470307 fuel pump instead.
If you don't have a buildsheet,tell me which month and asssembly plant your Chevelle was built at.
Old 09-18-2006, 06:51 PM
Mr70, my car was built the 3rd week of January 1970 at the Baltimore plant. Do I have the right pump?
Louis
1970 Ls6 Chevelle
Old 09-18-2006, 07:02 PM
Yes,for that plant at that time.
Old 09-18-2006, 07:48 PM
Chevy454 Chevy454 is offline
If I'm mistaken, there are different fuel lines according to which pump, also? Seems like I remember getting mismatched parts when doing my LS6...
Old 09-18-2006, 07:53 PM
Yes there is. The 40727 used the single inlet feed line and the 40768 used an additional return line to the tank requiring different fuel line clips and fuel sending unit.
Rick
Old 09-18-2006, 07:54 PM
Thought so...usually takes me 2 tries to get the correct parts!
Old 09-18-2006, 08:04 PM
Also if your early built,(#727 pump equipped),1970 vehicle was sold brand new in the state of Calif. & certain parts of Nevada and Montana,it too received an additional return line on that #727 shallow pump.
RPO NA-9 Evaporative Emission Control.
Old 09-19-2006, 12:41 AM
Mr 70, Could you include your thoughts on 1970 L-78 Camaro fuel pumps , the earliest example of which is my own 01C Norwood.
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 09-19-2006, 12:55 AM
DarrenX33's Avatar
Chuck in the case of my car. The buildsheet states 727 which is part # is 6470424. But you should know that already huh?
1969 Z28
1972 Corvette
