Old 09-15-2006, 05:13 AM
67L78conv 67L78conv is offline
Default 1967 Camaro RS SS 396 375hp L78 Coupe
I am listing this car on behalf of the current owner, car is located in Ohio.
Offered is a very nice original documented 1967 Camaro RS SS L78 4-Speed coupe with 4.10 rear. Currently one of only 75 known remaining L78 coupes according to CRG. The car is currently red but was Madeira Maroon from the factory with standard black interior. The car currently has a 1965 396 engine (from a transistorized ignition car) with aftermarket intake, headers, carb, HEI, etc. transmission has been converted to an automatic (4-speed hole in floor has not been tampered with). The rear is a correct 67 twelve bolt traction arm rear end with 4.10’s, it may be the original but I could not get the numbers off it due to aftermarket exhaust. Body has had Fenders, quarters, and outer wheel houses replaced with NOS metal. Rockers and doors are said to be original to car and are in excellent condition with no signs of rot. Emblems have been replaced with a combination of NOS and aftermarket. RS headlight work great. The interior is in excellent condition with original seat covers except for the driver’s side bottom. Sea belts are original and properly date coded, headliner is original, etc. all in great condition. Floors are good except for three small spots that need to be fixed, 2 in trunk will need patches just behind the shock towers about and one around the passenger front floor drain. The rest of the floors including the areas around the 3 spots are excellent. Trim tag and pop are original and reflect the car as being a true RS/SS L78 4.10 rear car. I will be answering questions on the car for the owner as I have spent a fair bit of time inspecting and verifying it. For more info call 732-361-8510 or e-mail [email protected] PM’s are welcome as well to 67l78conv.
