Old 09-08-2006, 11:23 AM
zl12iv zl12iv is offline
Default 69 copo clone PROJECT
this car is in euro primer/with a sealer car has no rust issues,little body work needs to be adresst,RS front clip
fenders Goodmark the under carrige is real clean in black
the car needs exhaust,clutch fylwheel presureplate linkage
the 427 corvette motor steel crank 8qt pan studed block
with ZL-1 alum heads.800 holley roller cam runs hard,an responsive,starts up smooth an with tap of key..
12 bolt BU code 373 axcle Z 28 housing not in car M-21 from the same Z 28 BU code not in car both need to be adreest.
has 10 bolt with mono leaf in the car .......
the interior new headliner,new carpet,new markers,new seat sliders,the front seats black,back are white,no door panels
needs proper cooling ,an grille...I am asking 22k or with out the motor 16k ..if i paint the car ? can be worth 40k maybe.
i have no energy to finish the car i am restoring a 70 RS Z-28 an I am almost finish this has been on going for almost 2 years....Or the 70 RS Z-28 hugger #s match for 40k you finish , Thank You .....Joe
[email protected]
70 RS Z28 400TURBO hugger
69 427 L89 400TURBO 12bolt BV
