Old 09-05-2006, 03:44 PM
SAUSAGE SAUSAGE is offline
Default Original ZL-1 and todays pump fuels.
Hi Guys.
My first post to this site.
Can the original vintage 1968 ZL-1 and or L-88 427 with 12.5:1 Compression ratios and solid tappet cams run on todays punp fuel USING a octane/additive? If so, which additive?
Where the ZL-1 and L-88 ever offered with multi carbs in lieu of single 4 barrels? If so, which manifold and carb set ups were used?
Would the factory single Holley carbs on the ZL-1 and L-88 out perform a factory Tri Power system?
Respectfully. Sausage.
