Old 09-02-2006, 07:08 AM
67L78conv 67L78conv is offline
Default 1967 396 parts needed
I am trying to help out a friend with his parts hunt (yet another L78 Camaro owner). He needs a lot of drivetrain parts at the moment, for the heads he will take either type. The date codes below are generic month/week all parts needed are 1967 dates. If you have any of the parts or leads please send me a PM.-
3902406 4 Bolt 396 block cast 04A through 05E
3919840 Heads cast 05A through 05E
3904391 Heads cast 03A through when they ended in May
3869978 3 deep groove crank pulley (cast iron)
3906656 2 deep groove water pump pulley
3873847 Deep groove power steering pulley (cast iron 3 spoke)
3885069 Aluminum intake Cast 03A through 05E
3909880 Right side exhaust manifold same dates
3909879 Left side exhaust manifold same dates
3910 Carb 03C through 06A will take a 3911 instead
1111170 Distributor 03A through 06A
12 Bolt Camaro traction arm mono leaf Posi rear prefers 3.73, 4.11 or 4.56 but will consider all
In short if you have an entire dated motor it would save him a lot of time hunting down the pieces.
Thanks guys,
Mike
Old 09-04-2006, 12:24 AM
Default Re: 1967 396 parts needed
Forgot the water pump-
3856284 Casting dates 03A through 05E
Old 09-24-2006, 06:13 AM
Bueller....Bueller?
Someone has to have some of these parts.
Old 09-24-2006, 06:22 AM
427king 427king is offline
Yenko Paid Member
Mike, youve already talked to the guy that has 85% of those parts
Old 09-24-2006, 07:10 AM
I have a 1107365 starter dated 7F12. If you're interested send me a PM. What is the trim tag date?
Martin Foltz
68 Camaro SS-396
Old 09-24-2006, 10:17 PM
And talked and talked and talked and... The phone bill is starting to hurt at this point.
Mike
Old 09-24-2006, 10:43 PM
ssl78 ssl78 is offline
I have a block the date on the pad is T0420EU there is also a vin still on it
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 09-25-2006, 12:48 AM
John,
Thanks. If it is a four bolt block he will be interested. If it is a two which I think all EU 350hp engines were he will wind up passing on it. He is not dead set on a specific date for the block but it does need to be a four bolt 406 cast block. All I can say is he is a picky guy.
Mike
Old 09-26-2006, 07:10 AM
Pacecarjeff's Avatar
Pacecarjeff Pacecarjeff is offline
Martin,
Sent you a PM.
I'll buy the starter.
Thanks!!!
Jeff
Old 09-26-2006, 08:07 AM
Sent you a PM.
Martin Foltz
68 Camaro SS-396
