Old 08-17-2006, 07:11 PM
Pacecarjeff's Avatar
Pacecarjeff Pacecarjeff is offline
Default Cooling Fan Question.
I have seen that all of the early Chevrolets used the short water Pump through 1968 (except Corvette = through 1972) They all used a fan with 3" bolt spacing. Now I find out from some that the 67-8 Z/28, as well as the L-78 used the later 3.25" spacing.
That is the spacing used for the later "long" water pumps.
Are the water pumps different on those 2 67-8 Chevy applications, as to use a differnt fan and clutch.
I know that all the other motor divisions used the larger spacing, and Chevy was different. Why were these 2 applications different then the rest of the Chevrolet engine line?
Old 08-18-2006, 12:22 AM
Default Re: Cooling Fan Question.
All the information was on the CRG site.
I am all clear on this.
Look here: http://www.camaros.org/coolingsystems.shtml
CRG Research Report - 1967-69 Cooling Systems
Old 08-18-2006, 12:46 AM
Steve Shauger's Avatar
Administrator
I believe the clutches were different, due to the high rpm range and performance application of the L78 and Z28.
www.vintagecertification.com
Old 08-18-2006, 03:57 AM
Yes, the clutches would have to be different in order to fit.
I would imagine they are VERY rare.
This is unusual that the fans and clutches are different from the Corvettes - all the 427's, even the L88, and L89 cars used the 3" spacing. Wonder why GM felt those 396's and 302's needed something different?
