Old 08-16-2006, 07:48 PM
Mike Mike is offline
Default Won't go above 45 MPH
A buddy of mine recently purchased an '80 or '81 Trans Am that had been in storage for 9 or 10 years. The car has low miles and was owned by an older lady since new. The problem is that the car won't go above 45 MPH??? It has good take off but once it gets to 40 to 45 is bogs down. He's talked to two mechanics and they both said it needs a motor rebuild at a cost of $5K. He said the oils clean, it doesn't blow smoke and there's no apparent leaks anywhere. Are there any emissions controls that might be holding this car back?? Anybody else ever experience this before? I just find it hard to believe that it would need a motor rebuild from sitting for 9 years. I could see the valve seals needing to be replaced but that shouldn't cause the car to bog at 45.
Thanks for any suggestions.
Mike
Old 08-16-2006, 07:51 PM
Default Re: Won't go above 45 MPH
I had a car that did this.
It was the Exhaust Heat riser that was stuck closed.
Check the C.C.,or maybe a dead mouse in the tailpipe?
Old 08-16-2006, 07:55 PM
Mike,,,It sounds like the catalytic convertor is plugged. I would go there first..........Bill S
Old 08-16-2006, 08:02 PM
enio45 enio45 is offline
Mike, exhaust related.........
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 08-16-2006, 08:06 PM
TDW TDW is offline
Fuel filter plugged or collapsed?
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 08-16-2006, 08:12 PM
I knew you guys would have some answers....thanks for the info. I'll forward your suggestions and see if he can fix the problem.
Mike
Old 08-16-2006, 08:41 PM
I had this happen on an '86 Trans Am - it was a blocked cat converter. It's easy to test, just drop the pipe - and go for a noisy test ride
BTW: eventually, it will get worse to the point that it won't run at all - especially after it gets hot. The cat will completely block off the exhaust until it cools down.
Old 08-16-2006, 08:55 PM
budnate's Avatar
budnate budnate is offline
ditto....
Old 08-17-2006, 04:07 AM
scuncio's Avatar
scuncio scuncio is offline
Gotta be the plugged cat...I remember doing a cool 70...60...50...40mph on I-75 in my '85 Parienne...ugh.
Old 08-17-2006, 11:03 AM
mssl72's Avatar
mssl72 mssl72 is offline
I gotta chime in on the plugged CAT. My sisters '87 Buick had the same symptoms. The CAT was choking the life out of it. It was like a new car when it got replaced. And it was a lot cheaper than rebuilding the engine.
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
