Old 07-19-2006, 07:29 PM
COPO COPO is offline
Default 1969 Nova Wheels & Tires
I am thinking about getting a set of American Racing 15x7 TTO's for my 69 Nova. What size tires will fit on the front and rear without any clearance issues? thanks
Old 07-19-2006, 10:34 PM
Default Re: 1969 Nova Wheels & Tires
Charlie, an F70 on the frt is about right although E70x14s were what came on SS novas. G60 is about as big as you can go on the back without clearance issues. The height difference in the size, 70 vrs 60 usually give the car a little frt end rake.
Old 07-19-2006, 11:12 PM
Is that what you look for in sheep????
Jake is my grandson!!
Old 07-20-2006, 02:38 AM
...you need special boots for that!
wilma
Old 07-20-2006, 03:20 AM
mnyenko mnyenko is offline
The back spacing on the rear wheels is important. You will need at least 4" back spacing. 4.5" is best. Then 25560R15 will clear. I run 21570R15 on the front. But 225 will fit if you prefer. Earl
Old 07-20-2006, 03:58 AM
Thanks for the replys. Earl are you using a 15x7 wheel with the 215x70's for the front?
Old 07-20-2006, 04:53 AM
MosportGreen66's Avatar
I just put 215/14's in the front and 245/14's in the rear of our 1972 Nova SS.
The car is running on some original "CL" 14x7 wheels.
-Dan
Old 07-20-2006, 05:38 AM
jasonL78 jasonL78 is offline
just so you know 215/70 on a 15x7 rim are to big on the front of a nova. Mine hit every so often should of gone with a 205/70x15 tire. I have 235/60 on the rear both front and rear rims have 4" back spacing.
Old 07-20-2006, 05:56 AM
Jason, can you post a side picture of your car? I would like to see how it looks with the tires you are running.
Old 07-20-2006, 07:04 AM
What I meant to say... not that it matters now anyhow...
I'm running 215/70/14s in the front and 245/60/14s in the rear.
