Old 07-09-2006, 11:27 PM
Default Odd '163 intake
Hey guys!
I own several of the 3933163 intakes and have seen tons of
them over the years. I ran across this today and was
instantly stumped. It's an older style 3933163 intake with
a spread bore pattern for the carb.. Anybody ever seen
anything like this before? Could it be for marine applications?
If so, wouldn't it still be a different part number?
This is a strange one.....
Steve
Old 07-09-2006, 11:45 PM
firstgenaddict's Avatar
Default Re: Odd '163 intake
Looks like someone modified a 163 probably for racing where they had to run a quadrajet.
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 07-10-2006, 01:34 AM
The marine-intakes I have seen all had brass waterpassages.
Anders Stålklint.
Old 07-10-2006, 02:40 AM
SuperNovaSS SuperNovaSS is online now
I believe the intakes with brass passages carried a different part number. The later 163 intakes had the snowflake and firing order is different spots. Possibly a late 70's service part? It sure would look the part one a carb was mounted.
Old 07-10-2006, 02:47 AM
Give us a straight down shot directly over the carb mount surface looking into the plenum and an oblique view from one of the front corners would be great (I want to see the machining marks in the secondary openings).
I beleive that it is a standard 163 with the plenum opening for the carb modified.
~JAG~
NCRS#65120
Old 07-10-2006, 08:16 AM
69L72RS 69L72RS is offline
I think you can see the step where the secondaries were machined in instead of cast in, in the top right picture.
I have had them like this in the past, where the intake was modified to work with Q-jets without using a spacer/adapter.
Eric
Old 07-10-2006, 10:17 AM
That's all the images I have of this intake.
Julian - You've seen '163 intakes with a spread-bore pattern
from the factory before? That doesn't make any sense. The
'163 intake was an SHP item and Rochesters were not. I
thought this was an oddity, now I'm even more confused.
Steve
Old 07-10-2006, 04:32 PM
Steve,
Sorry for the confusion.
I have had a few that were "modified" to be used with a Q-jet carb. They were not factory production intakes. One of them was done using hole saws to cut the larger openings, because the guy didn't have a boring head for his mill. You can imagine what it looked like.
Some people just won't run a Holley carb and have to have a Q-jet to be happy.
Again, sorry about the confusion.
Eric
Old 07-11-2006, 08:49 AM
indyjps indyjps is offline
some stock car classes required q jets some required iron manifolds.
Old 07-12-2006, 10:47 AM
Here's an original '163 intake. Guess someone could have
used a hole saw or similar to open up the intake in question
for a Rochester. Sure hope they didn't try to run that
setup against a set of oval port heads.
