Old 07-01-2006, 04:42 AM
snowmobileshocks snowmobileshocks is offline
Default 1969 Camaro Found With COPO 12 Bolt ?
Hi,I recently bought a 1969 camaro roller,no motor or trans, with a X-11 code,front disk brakes,big block heater core,and the accelerator arm does have the extra bracket for the switch to activate the cowl hood.I went under to look at the 12 bolt and found the BE code on rear.It now has 456 gears?I can read only one of the three digits for the year,and it looks like a (8).The car has a Febuary build date, and rear is June.I am wondering if someone just had the rear,and put it in this car,or if I should dig deeper to see if this a COPO ? I have contacted the 4 previous owners back to 1982 and the trail stops.All previous owners said the same thing that they had a small block in the car,but was under the impression it was a big block car orginally.What are the BE coded 12 bolts worth,if this is not a COPO. Any help on this would helpfull,post or email me at [email protected] THANKS
