Old 06-27-2006, 07:20 AM
Bigblockhappy Bigblockhappy is offline
Default LS6 cam
Can someone post the GM part # for the LS6 camshaft and is it still available thru the dealers.
Thanks
1970 Ls6 Chevelle
Old 06-27-2006, 07:24 AM
Default Re: LS6 cam
It's Part #3863143.
I thought Rob or Pete stated this was still available through Crane?
Old 06-27-2006, 07:37 AM
Default Re: LS6 cam
I just checked on GM Parts Direct and that part # doesn't come up.
Is this camshaft discontinued thru GM?
1970 Ls6 Chevelle
Old 06-27-2006, 07:41 AM
Default Re: LS6 cam
Here it is... 3863143
Old 06-27-2006, 07:42 AM
Chevy454 Chevy454 is offline
Default Re: LS6 cam
Just order it from Crane: GM/Crane blueprint 143
Old 06-27-2006, 07:46 AM
Default Re: LS6 cam
Thank you
1970 Ls6 Chevelle
Old 06-27-2006, 07:47 AM
Steven J Steven J is offline
Default Re: LS6 cam
I noticed that the valve lash spec for the Crane cam is significantly different than the original GM cam. Anyone know why ?
Steve
Old 06-27-2006, 07:50 AM
Default Re: LS6 cam
Not sure...they just changed it within the last year on the cam cards, even though everything else is the same...my guess is that the rash of flattened cams within ALL cam manufacturers has them tightening up their clearances...but that's just a guess. I have that cam and it likes the 24/28...
Old 06-27-2006, 08:50 PM
Default Re: LS6 cam
Did the cam mfg's change the type of metal composite in their blanks?
Old 06-27-2006, 08:59 PM
Default Re: LS6 cam
I kinda think they did, but have never gotten a straight answer...last I knew the better part of all the cam blanks used in the market came from the same place, and *all* cam mfg's have been having cam failures. Looks like simple math to me!
Jim Lerum was the one who spotted the different lash on the 143 card...he built an LS6 and then had a cam go bad, so had another put in...he was checking out his newest cam card and spotted the 25/25 and told me about it...everything else on our cards was the same, and it even took them a while to change it on the website...but for whatever reason they call for 25/25 now...
