Go Back   The Supercar Registry > Comments/Suggestions > Comments, Suggestions, Problems
Old 06-22-2006, 06:16 PM
Default Macro Setting
I'm trying to take a digi-pic of a part number, but can't find something called a macro setting to keep it from being blurry or washed out with the flash. Any tips?
Old 06-22-2006, 06:35 PM
Default Re: Macro Setting
It should be an icon of a flower on your camera dial.
Sometimes it actually shows up clearer w/o the Flash enabled.
Old 06-22-2006, 06:46 PM
Ok, cool - I'll look for that little thingy.
Old 06-22-2006, 08:06 PM
bigchevydaddy bigchevydaddy is offline
You might want to disable the flash, at close range it can be more trouble than help; just light the part with a shop light or other light source. You can also avoid blurry close ups by keeping the camera a reasonable distance away and zooming in to the close up.
Good luck, BCD.
Old 06-22-2006, 08:30 PM
Oh well, found the flower, turned off the flash, but it's amazing blurry - even from 4 inches away! The manual says it will be ok up to 2 inches away, so I must have some other setting messing things up! Trying to take a picture of a part number stamped into a diverter valve.
Old 06-22-2006, 08:46 PM
I am watching this with hopes as well Marlin. I too have a camera that makes this claim and no matter what I do, it will not focus when close. Standing further away and zooming also does not help.
Mine is a Sony Mavica. Archaic yes but it was great when the first memory card cameras came out because I could download into anyones computer whereas the others could not if the software was not present. Still works good however.
Rick
Old 06-22-2006, 09:22 PM
mockingbird812's Avatar
Attempting to take these types of pix the camera has to be held verrrrry still. Try the macro setting using your camera's timer (most have this feature) and a tri pod. If no tri pod, start stacking stuff till you get the camera where you want it.
Good luck!
Sam...
Old 06-22-2006, 11:00 PM
budnate's Avatar
budnate budnate is offline
holding still is one of the keys, find a rest to land your arm on and also the advice of staying back about a foot then zooming in works well, hold your button part way down let the camera focus and push the rest of the way once it looks good, also I have found if I am slightly off left or right of the thing when I hit the button it seams to be less sensative to the flash but still light up what I was after in the pic.
Old 06-22-2006, 11:06 PM
All good suggestions...the timer trick I learned from one of the photogs from Chevy High Performance magazine...works well for night shots if you don't have a tripod
Old 06-23-2006, 12:50 AM
John Brown's Avatar
I have two Sony Mavicas with floppy slots and the flower setting. I can take pictures of Holley carb numbers an inch away. You have to push the button half the way down and let the camera refocus before you snap the picture. Here's a picture of a quarter from 1/2 inch away.
John Brown
