Old 06-22-2006, 06:22 AM
mnyenko mnyenko is offline
Default 64 Ford Galaxie 427
I came across the remains of a 1964 red/red Galaxie today. It was a manual trans. The door tag and vin are still there. The door tag says rear end code 4 trans 1. The junyard wrote in yellow marker 427 4x2 on the hood. Motor and trans are gone. Is there a way to find out if this was a factory 427 car? Does it have any value as a rusty incomplete car? Earl
Old 06-22-2006, 06:44 AM
Default Re: 64 Ford Galaxie 427
R code in the vin ?
Old 06-22-2006, 06:50 AM
I will have to go back and check out the vin. Did not write it down. Just looked at the door tag. Earl
Old 06-22-2006, 07:06 AM
Can you take some digital pictures of it & show them here?
Old 06-22-2006, 07:21 AM
I will take some digital pictures. Should have them up early next week. Thanks Earl
Old 06-22-2006, 07:33 AM
bkhpah bkhpah is offline
It should have an "R" in the door jamb tag and also on the firewall passenger side will have a stamped tag that is part of the firewall. "Q' is a 427 410 HP single 4 barrell...BKH
Old 06-22-2006, 06:58 PM
flyingn's Avatar
flyingn flyingn is offline
its up top of th efirewall and can be seen with the hood open from the top.. Look for thr R or Q (single 4 barrel carb)
Frank Szymkowski
Old 06-23-2006, 01:24 AM
The tag is still on the firewall. Tag is in the door as well. I do not think it has a R. Looked for that. It may have a Q. Will get back for a look early next week. With the digital camera. Earl
Old 06-29-2006, 08:39 AM
False alarm. No R or Q code. Some one got a good laugh with the 427 hood writing. Earl
Old 06-29-2006, 04:52 PM
At least you were smart enough to follow up and investigate. I have learned the hard way, follow up on every lead when possible no matter how far fetched.
Rick
