Old 06-15-2006, 11:52 PM
Denis Denis is offline
Default Under-cowl paint color?
Does anyone have an original paint 69 Hugger Orange non-Z28 Camaro?
I need to know if the area under the cowl panel (i.e. the area where the wiper transmission linkage is located) should be blacked out.
JohnZ states the area is supposed to be blacked out but I've heard from one owner of an original paint L78 (hotrodpaul here on yenko.net) that his is body-colored.
My car is Norwood 02D-built with white SS stripes if that makes any difference.
Old 06-16-2006, 12:09 AM
DarrenX33's Avatar
Default Re: Under-cowl paint color?
If you could somehow send a smoke signal to get in touch with Ken Barnhart...
Denis does it have to be Hugger Orange?
I honestly don't recall seeing a non-Z with that area blacked out....
1969 Z28
1972 Corvette
Old 06-16-2006, 12:55 AM
budnate's Avatar
budnate budnate is offline
lets look on this one...Hmmmmm
https://www.yenko.net/ubbthreads/show.../page/1#204846
Old 06-16-2006, 01:29 AM
Bud:
Good suggestion. Dana, you have a PM!
Darren:
I'm not sure if the blackout was done or not. Since it may have varied with assembly plant and/or car color, I'd prefer to compare with another original paint orange car. HotrodPaul's car is blue but doesn't have the blackout.
Old 06-16-2006, 03:30 AM
camarojoe's Avatar
The top of the cowl should be orange. The orange fogs over the top edge of the firewall, overspraying the black firewall paint on Norwood cars, and has a taped edge on LA cars.
Joe Barr
Old 06-16-2006, 03:48 AM
I'm talking about the color under the cowl panel, through the plenum openings where the wiper transmission is visible. On this original paint car, the area is clearly body colored with the wiper transmission black:
Yet I'm told that the factory assembly procedure included "black out" in the plenum area so that the wiper assembly wouldn't stand out so much. So I'm trying to find examples of cars to support this claim -- obviously the car pictured above doesn't, so maybe it's hit-and-miss or maybe it depends on assembly date or assembly line, or exterior color, or maybe it was just never done.
Old 06-16-2006, 05:45 AM
camaromb camaromb is offline
I just picked up an original paint orange non-z28 '69 Camaro. Like all the other original non-z28 '69 Camaros I've seen it's painted body color in the wiper arm area inside the cowl, no blackout.
Old 06-16-2006, 07:30 AM
Here is the top of the firewall on Barnharts ZL1
Old 06-16-2006, 07:58 AM
bkhpah bkhpah is offline
Never have I seen a blacked out cowl area on a car that did NOT have stripes. Ive seen plenty of white in that area on a white striped Z/28, without any attempt to blacked out. The wiper transmission is installed after paint...BKH
Old 06-16-2006, 09:49 AM
I believe JohnZ has said that the area was "supposed" to be blacked out, but it was pretty random as to how often it was actually done that way. This, and a orig paint PC that was orange here, are the only orig paint cars that Ive dealt with that was not body color in the cowl area (orig paint, black stripe Z):
And the body color was sprayed first, with the firewall paint fogged in to the upper half of the firewall rather than the other way around.
dave
TheMuscleCarGuys.com
