Old 05-26-2006, 05:29 PM
Pacecarjeff's Avatar
Pacecarjeff Pacecarjeff is offline
Default 1969 Z/28 Exhaust Manifolds and Smog System ebay
Original Complete Smog System. 1969 Camaro Z/28 - Or SS350 with A.I.R.
eBay Auction
System includes:
Exhaust Manifolds
Smog Pump - white fan
Diverter Valve and extension
Correct hoses, check valves, and clamps
Pulley
System has been proffessionally restored as correct non Fuctioning.
Original Exhaust Manifolds: 1969 Z/28 302, SS-350 w/Smog - Fantastic condition.
Part #3942527 LH - dated: C189 = March 18, 1969, 3946826 RH - dated: C179 = March 17, 1969.
Original Smog Pump 7801149 Dated: X05491S = Februrary 23, 1969 (54th day, 1969) - Beautifully restored - Turns freely. Perfect White fan - Original GF diverter valve - Valve #29295, nozzle #7034481, Ext. #3942599
Includes Z/28 - 3932458DA Deep groove (repro) pulley. Or if you prefer SS - 3927116AU Standard groove (original) pulley. Please choose one pulley.
This is 100% correct but non-functioning system - Very easy to convert back when you are ready.
The exhaust manifolds have been professionally tapped, and plugged from the back. They were then cleaned and sprayed with Hi-temp long lasting Eastwood manifold dressing. All threads and studs are cleaned and ready.
The pump is professionally restored, the internal fan blade is removed.
Includes original clamps, original hoses, original check valves, carb vacume line.
All you need is a set of repro smog tubes available from any restoration house for $80
Perfect for a correct system with out losing all that the horsepower associated with the AIR system. Correct for: Chevelle, Nova, Camaro. 350, 302, 327, 307 Chevrolet Engines.
Log design with A.I.R. smog.
100% all original part - Everthing is in Wonderful condition. Never any damage - no rust, no repairs, all threads are perfect - Ready to install.
<u>To be perfectly clear:</u>
Once this system is installed. No one will be able to tell it is non-functioning unless you tell them. It looks and performs exactly the same, just does not pump air. The pulley on the front spins freely, and does not draw horsepower from your engine.
These are ORIGINAL exhaust manifolds, and componets,
not repro - 100% GUARENTEED AUTHENTIC.
They are in beautiful / pristine condition.
The only part of this system that is repro is the DGroove pulley. But only if you choose that pulley instead of the original SS-350 SGroove offered.
USE THE "BUY IT NOW" FEATURE, AND SHIPPING IS FREE.
eBay Auction
