Old 05-23-2006, 07:41 AM
Zedder's Avatar
Zedder Zedder is offline
Default Removing chrome plating?
Is there a way to remove chrome plating on parts that should be painted (fans, pullies etc.)? Thanks
Mark
Old 05-23-2006, 01:45 PM
TDW TDW is offline
Default Re: Removing chrome plating?
Mark...I have used my blasting cabinet with glass bead in it to get chrome off before.If you can get a piece of the chrome loose, you can get under the loose chunk and kind of peel the rest off.It's not an easy or fast way to do it, but it has worked.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 05-23-2006, 05:02 PM
mrrec mrrec is offline
Mark:
The best (and only way, really, if it is good plate) is electrolytically. Take the parts to a small chrome shop and they'll put them in their tanks and strip them quick. Just as the chrome is electroplated, it is "electro -un-plated. They just reverse polarity.
Non-ferrous base metals can have chrome stripped by dipping in hydrochloric acid.
Dave
Dave
www.Z16Chevelle.com
Old 05-24-2006, 02:37 AM
Zedder's Avatar
Thanks guys...I appreciate the advice! The previous owner went to town in the late 70's
Mark
