Old 05-22-2006, 08:51 PM
k92 k92 is offline
Default ls6 oil pressure sending unit
The oil pressure sending unit on my ls6 consists of the sending unit and 2 brass fittings. The sending unit screws into one of the brass fittings which then screws into a larger brass fitting that screws into the block. Is this correct or has someone changed it? The fitting shown in Ground Up's catalog shows a 1 piece brass fitting,not 2 like mine? Help!!!
Old 05-22-2006, 10:46 PM
Default Re: ls6 oil pressure sending unit
Rob,
Incorrect. The sending unit screws into a 45* hex brass fitting.
Rick
Old 05-22-2006, 10:56 PM
k92 k92 is offline
Ok, thanks Rick. I guess the original owner probably changed it due to clearance problems with the headers.
