Old 05-15-2006, 04:32 AM
ssl78 ssl78 is offline
Default 1967 300 Deluxe Chevelle
1967 Chevelle 300 Deluxe original one owner CAL car. The POP says the original drivetrain was a 283 glide. The drivetrain now is a 468 Spectra built big block with 074 aluminum heads 163 intake coupled to a reverse manual turbo 400 with a 2800 stall. The rearend end is a 12 bolt with 488 gears with a spool and Strange engineering axels with c clip eliminators. This car is a 100% rust free all original metal car with mostly original lnterior. I was told it has run a best of 10:87 there is many timeslips for low 11 sec times this is on engine no spray. This car was featured abou a month ago under members ride if you need to read or see more pictures. This car would make a perfect car for pure stock since the body is 100% stock, or could be used to build a pro touring car. Price is 35k
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Attachments - The Supercar Registry 205268-000_0217edit.jpg 205264-postint.jpg 205263-post.jpg
