Old 05-07-2006, 02:47 AM
VintageMusclecar's Avatar
Default Tech tip regarding rear end control arm bushings
This should come in handy for the GM A and B body crowd...
Found an easy way to remove those stubborn old worn-out upper control arm bushings from the cast "ears" on the top of a GM 10 or 12 bolt rear end.
Using "Percy" (my trusty 5-lb sledge...think about it ), I knocked the bushings back until they were flush with the front of the "ears" on the rear end housing.
As I was about to put the big red wrench to the remnants of the rubber so I could use a hacksaw blade to cut through the outer shells like I've done countless times before, an idea struck me;
Using Percy, I "tapped" around the perimeter of the bushing until the outer shell began to collapse in on itself. Soon I could see the old bushing starting to cock sideways in the ear; with a few light taps with a drift on the front of the bushing, they literally fell right out.
Why didn't I think of this 20 years ago???
Hope this comes in handy for someone else.
Eric
