Old 05-05-2006, 04:19 AM
Alss's Avatar
Alss Alss is offline
Default Old SW tachs
Do most or all of the older tach..mid 60"s use a sender??or are some of them direct wire to the coil??..have a line on a old SW greenline..does not come with a sender, and no I dont have a model number....yet!. Thanks
Albert
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 05-05-2006, 04:34 AM
camarojoe's Avatar
Default Re: Old SW tachs
Most use a sender, some do not. If its the "Yenko" pedestal type, then it needs a 990B sender. They can also be converted to solid state, which is probably the smartest thing to do regardless, as the senders were not the picture of reliability.
Joe Barr
Old 05-05-2006, 04:48 AM
There are two models of the greenline pedestal. They both look the same externally. One uses a sender and one does not. It you take the rear cover off is it easy to tell. The transistorized tach(no sender required) has 3 pins labeled 4, 6, and 8. There is a wire that can be moved between the 3 posts to select the cylinders.
Old 05-05-2006, 05:12 AM
camarojoe's Avatar
Interesting. I've never seen an original SW greenline 970 pedestal tach that didn't require a sender.
Joe Barr
Old 05-05-2006, 05:47 AM
Alss's Avatar
This is the one..a little day 2 for my COPO.
Old 05-05-2006, 05:50 AM
Alss's Avatar
lets try it again
edit: wont let me upload any pics!!!whats going on??? Help!!
ALbert
Old 05-05-2006, 05:55 AM
Alss's Avatar
Joe, do you have any info on who does that service..the solid state conversion?? Thanks
ALbert
Old 05-05-2006, 06:03 AM
Alss's Avatar
OK here is the e-bay link;
http://cgi.ebay.com/ebaymotors/ws/eBayIS...N%3AIT&rd=1
Spent way more than I wanted to but........I wanted it!! ..looks just like the one in the 68 Yenko picture in the other thread with the newly found 68 Yenko. It will make a good day 2 addition
ALbert
Old 05-05-2006, 06:26 AM
Tach repair. Auto Instruments! Very reasonable and good work. 877-450-0110. Easy to deal with. Sam
camarojoe's Avatar
Al, sent you a PM.
Joe Barr
