Old 05-02-2006, 08:36 AM
MosportGreen66's Avatar
Default 1969 Chevelle Question
Edit: Sorry guys...
Would a 1969 Chevelle Super Sport L-78/L-89 have 842 Aluminum heads? If not, what code would be the correct application? Same goes for a 3955272 block? If not, whats correct?
Many thanks.
Old 05-02-2006, 08:42 AM
jfkheat jfkheat is offline
Default Re: 1969 Chevelle Question
I may be wrong but I think it would depend on the build date of the car. I think the 074 heads were used on some of the 69 L-89 engines.
James
1968 Beaumont SD396
Old 05-02-2006, 08:45 AM
mockingbird812's Avatar
block:
3955272 is correct casting number for a 69 L78 block. They were made in 2 and 4 bolt configs. Will have to check the hole config. at the oil gallery area or drop the oil pan to confirm.
heads:
842 is correct for a 68 or 69 396 L89 application (107 cc chamber).
Sam...
Old 05-02-2006, 08:51 AM
074's are correct for the 1969 L-88 Corvette,1969 Zl-1 Camaro & Corvette,& 71 LS-6 Corvette also.
842's are correct for the 1968 L-88 & L-89 Corvette,1969 L-89 Corvette,1968-9 L-89 Chevelle & Camaro,1970 L-89 Chevelle.
