Old 04-20-2006, 01:12 AM
highpockets highpockets is offline
Default Big Block casting # Hi perf ?
Found an old BBC engine very cheap,steamed it off and I see what appears to be some conflicting info.I am hoping you experts could help decipher if I have a good one or just run of the mill BBC. Casting # is 14015445 which if I translate correct is 78-87 454 truck motor 2-4 bolt mains.The weird part is above the oil filter pad is cast hi perf pass. The stamped pad on RF indicates CAF159406,intake is 3931067,cast iron 4bbl. I have not torn it down,but have a friend who wants it for an old truck and I dont want to give it away if its a good one(I do have a 67 RS to play with if it turns out to be a keeper Any help/leads would be appreciated.
Old 04-20-2006, 01:27 AM
PeteLeathersac's Avatar
Default Re: Big Block casting # Hi perf ?
Take the last digit '5' off the block casting and it's a '445' truck block....and the intake appears to be a '69 item? . Is there more info on the 'stamped pad' extended block/deck surface in front of pass side head? .
~ Pete
Old 04-20-2006, 01:35 AM
Mr. T Mr. T is offline
Yes, the intake manifold is for a 69.
Passenger, 427, (335hp, 390hp)
Chevelle, 396, (L35, L34)
Camaro, 396 (L35, L34)
Nova, 396 (L34)
All with 4bl Quad.
Tony
Old 04-20-2006, 02:23 AM
Nope,although there seemed to be more stamped letters/numbers on a little pad,center front below intake rail ? I guess I need to pull a valve cover and oil pan and see what it is ?
Old 04-20-2006, 02:26 AM
And,why would a truck block have the hi perf pass cast above the oil filter ? Are all big blocks like this ?
Old 04-21-2006, 11:14 PM
70CitrusZ's Avatar
70CitrusZ 70CitrusZ is offline
A lot of bbc stuff says "high perf" run of the mill or not.
2012 ZL1 black M6
1968 L36 4 spd Biscayne
1957 270 hp Corvette
Old 04-21-2006, 11:25 PM
DM69SS DM69SS is offline
I have a 2 bolt 78 454 from a suburban that has hi perf cast on it. Seems they put that on a lot of stuff
Camaros
69 SS L78, 69 327, 2000 Z28 Vert,
Old 04-22-2006, 12:59 AM
Keep in mind these are really passenger car blocks in the light truck series and not the tall 'truck blocks' like 366 etc. . Almost any of the Mk1V stuff is worth putting the grab on but sure getting tough to come by anymore...keep an eye out for 'Burbans/Trucks w/ that little 454 badge in the '73&up grilles. .
~ Pete
Old 04-22-2006, 03:26 AM
Yup,for the price(little enough ! ) I couldnt pass,complete and not full of water/rust,seems like any big block is getting hard to find these days. Thanks for the input,as a side note,how do I go about posting pics ? Customer dropped off a car,sitting in grandmas garage since 1979(when grandpa died) kids put a battery in it and drove it down to me.Want to get it tuned up and drivable ! 1967 mustang fastback,390 Auto,A/C with a working 8 track,original paint,interior everything ! I can barely type after drooling alll over this thing.I realize its not a supercar,but to see one drive in at all,seems kinda cool to me.Tried to give them my corvette and take the mustang but NO WAY,not grandpas old car. What a bummer !
Old 04-22-2006, 09:03 PM
mockingbird812's Avatar
Have you deteremined whether yr motor is a 4 bolt or not? Drop the pan or check out the hole configuration by the oil galley.
Sam...
