Old 03-17-2006, 02:40 PM
69 Code51 Z 69 Code51 Z is offline
Default 69 621 Bellhousing Correct Finish
Is the bellhousing suppose to be painted or natural? I've heard alot of different opinions. Carl
Old 03-17-2006, 03:21 PM
drdave69 drdave69 is offline
Default Re: 69 621 Bellhousing Correct Finish
With my limited knowledge I believe that the bellhousing was bolted to the engine when the engine was painted. It received overspray but wasn't completely painted.
Dave
1987 Grand National
Old 03-17-2006, 05:50 PM
TDW TDW is offline
For whats its worth, when my 68 Z28 was judged for Diamond, they deducted some points because there was no overspray on the bell housing.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 03-17-2006, 06:07 PM
I honestly do not know small blocks but my understanding was that Tonawanda big blocks had many items installed when the engine was painted such as bellhousing, valve covers, exhaust manifolds, etc whereas the small block plants did not practice this. For that reason, I always thought the small block bellhousings would not have overspray.
Rick
Old 03-17-2006, 06:14 PM
bertfam bertfam is offline
From JohnZ (John Hinckley) in a prior post on the CRG...
The bellhousing was on the engine when it was painted; it will show varying levels of overspray on the forward 4"-6", or more, or less, depending on how the sprayer felt that day.
Ed
Ed Bertrand
1968 RS/SS L-89
396/375 Convertible
CRG Member
Old 03-17-2006, 06:35 PM
jl8z28 jl8z28 is offline
I went through the Diamond judging and my bellhousing was painted orange and they accepted it. I think that they will accept it natural with overspray also
Old 03-17-2006, 06:46 PM
SB's were oversprayed as well, some a little, some a lot, but rarely (if ever) was the entire bell painted orange.
Old 03-17-2006, 06:50 PM
I recently purchased a '621 bell housing that was originally
attached to its matching L/71 ( never separated ). This bell
housing has a heavy overspray around the entire perimeter
of the mounting surface, with the exception of the clutch
fork area. This area was left alone. It even has the
original yellow pencil inspection mark.
I bought it mainly because it was as originally painted and
time has changed overspray if you get my meaning. I always
try to purchase originally painted componentry what I can,
as long as I have a reasonable expectation that they are
indeed original.
Steve
Old 03-17-2006, 07:06 PM
Steve,
What sort of yellow inspection mark was on the bellhousing? I have seen this on rare occassion.
Rick
Old 03-17-2006, 07:40 PM
Below are pictures of Jack Seymour's 22K mile 70 Z-28.
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
