Old 03-17-2006, 07:47 AM
Default Building up plastic
The hard plastic "horn bar" (center section) for my '70 steering wheel has two bosses molded into the back. These bosses receive brass inserts which appear to have been pressed in. The brass inserts receive Phillips screws which attach the center section to the metal horn actuator and thus to the steering wheel.
On the standard wheel I have, the inserts have been pressed in level with the top of the bosses.
On the burled wood SS wheel, the inserts are not pressed all the way in (about a 1/4 inch out), and one of the bosses has a side broken off.
I have two questions: Should I try to press the brass inserts the rest of the way in on the SS center section? Will I risk breaking the bosses worse than they are now? If I dont press them in, won't the center section sit noticeably too far from the steering wheel?
AND, What is a good product to build up the boss where the piece is broken off, so there is support around all 360 degrees of the insert?
Thanks for any help on this -
-Sam
Old 03-17-2006, 07:57 AM
SS454 SS454 is offline
Default Re: Building up plastic
Not sure about pressing them on but as for what product to use 3M makes a system call AutoMix which is a two part epoxy that will work great. We use these in collision shops every day and the part # that will work good is 08115 it's called panel bond for putting on door skins and other sheet metal with out welding. But it works great on steering wheels i have some drying right now on my 69 SS wheel. Hope this helps.
Rick
69 RS Camaro NOT Working on it for now!!
Old 03-17-2006, 08:23 AM
Thanks Rick, how do you apply it? The spec sheet says a 3M 08117 applicator gun is required?
-Sam
Old 03-17-2006, 08:48 AM
Yah you need the gun. If you buy 6 08115 i will throw in the gun for free. Thats what i do for my shops. If you know some one at a collision shop they should have one that you can use for a night. Other wise the gun sells to the shop for around $100.00 List is $170.00 give or take. Most jobbers will sell it to you for what they sell it shops for at least we do. Let me know if can,t find one can get you at 10% over cost plus shipping.
Rick
Old 03-17-2006, 09:34 AM
Rainer Rainer is offline
Sam - Another alternative is a more generic type epoxy like JB Weld. I use this regularly to repair steering wheels and a variety of plastic parts. Cost will be around $5 at Walmart or any hardware store.
1969 Chevelle SS396 L78 M22 4:10 Tuxedo Black
1970 LS3 Malibu 400 BB convertible
1970 LS3 Malibu 400 BB coupe
1970 Chevelle 300 series LS3 400 BB coupe, special order Monaco Orange
1970 Chevelle Concours Estate LS3 400 BB wagon
1970 Chevelle SS396 L78 M21 3:55 Tuxedo Black
The Following User Says Thank You to Rainer For This Useful Post:
mhm1966 (03-28-2022)
Old 03-17-2006, 09:46 AM
Sam, How about the DurAMix line of products....I have the gun for that you can borrow.........
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 03-17-2006, 02:32 PM
69 Code51 Z 69 Code51 Z is offline
Does anyone have a suggestion on filling a drilled 1/4 hole in a console?
Old 03-17-2006, 06:43 PM
Dan007 Dan007 is offline
JB weld works great use the original JB and not the JB quick. I used this on a 70 chevelle console in several areas. One area was a hole the size of a dime. After drying I sanded and paineted it still is working great 3 years later.
Old 03-18-2006, 05:50 AM
Duramix is a 3M product now and the stuff you buy today uses the same gun as the automix. 3M couldn't beat Duramix so if you can't beat them than just BUY them.
Rick
