Old 02-27-2006, 10:35 AM
musclcar musclcar is offline
Default 15x10 slot dish mags question
just found a set of western 15x10 slot dish mags with 3-1/8th BS i couldn't not refuse and bought them.now here's the question these rims are a uni-lug bolt pattern that fit 5 on 4-1/2 and 5 on 4-3/4 and the do not have the washers for the lugs. were can i find these washers so i can mount these rims on my car could i use washer from the cragar s/s rims since they're uni-lug ??
72 camaro ss 350 sbc 425hp old school day 2 build-up
Old 02-28-2006, 12:49 AM
Pantera Pantera is offline
Default Re: 15x10 slot dish mags question
I may be getting them mixed up and if memory serves me right. The lug holes in the wheels are like a obglong slot just to look at them. There is not a depressed area for the formal uni-lug rectangle washers to fit into the face of the wheel. Instead they just use the correct size lug nut with a thick round washer. When using the 4 1-2" pattern that fit a Ford the lug nuts on the wheels will be centered in the slot nearest the center of the mag wheel and outer on a Chev(4 3/4"). They seem to work quite well that way with little or no problems that I have ever encountered as long as they were tightened correctly. You just want to be sure the sholder on the lug nuts are the correct diam. as the slot in the wheel.
Pantera
70 BM Phase III GT Vette
69 BM SS427 GT vette?
69 L78 Nova 7k mi
73 Pantera
69 Vette B/P SCCA
Old 02-28-2006, 01:54 AM
Pantera
yep they have a oblong holes in them and have no ridge cut in them for a offset washer. so i just need to take them to a tire shop to find the correct lug nuts then
thanks Pantera
