Old 02-12-2006, 09:12 PM
rsatz28 rsatz28 is offline
Default Help - Turn Signal Cancel Cam Replacement
Any tips on how to replace cam? I did buy the lock plate retainer tool.
Rob
69 <font color="orange">HO</font> Z-28
Old 02-12-2006, 09:27 PM
Unreal Unreal is offline
Default Re: Help - Turn Signal Cancel Cam Replacement
remove the wheel, remove the metal cap, use the tool to relieve pressure on the retainer clip, and remove it. the cam is held with a couple of screws. grease everything well with lithium grease, and reverse order.
I put everything on a screwdriver blade in the order of removal, so I can remember what order to put everything back.
Old 02-12-2006, 11:35 PM
Maybe I'm being dumb today, but I don't see or recognize the snap ring. Help
Rob
Old 02-13-2006, 12:23 AM
I've attached a picture in hopes that someone can help me.
Rob
Old 02-13-2006, 02:44 AM
Chevy454 Chevy454 is offline
I can't tell from the picture, but you have to push the *hub* type deal down to see the snap ring...we have a large "U" shaped tool that goes over the top of the shaft itself and pushes down on the outer edges of the hub thingy as you tighten it...you won't be able to push it down by hand, so you're gonna have to figure something out. I've seen Mo pin a big screwdriver against his chest to hold the hub down long enough to get the snap ring out, but he's 6'5 &amp; 300...so I use a tool. Pop into a local parts store and look at a Hayes manual for any 60s/70s/80s Chevrolet...they're all about the same.
Old 02-13-2006, 05:24 AM
Dusk Blue Z Dusk Blue Z is offline
Your picture shows the top plate and snap ring already off. The top plate is what seats the upper bearing. I think there are 3 screws that hold the switch in at this point, you have to cycle the switch to get to all the screws. Unplug the flat plug on the wiring harness at the bottom of the steering column and give a yank, but first hook a wire or string to the wires to use when you install the new switch and want to feed the wires back down.
Good luck.
Mike
Old 02-13-2006, 02:59 PM
I think you hit the nail on the head. The top plate and snap ring is missing. No wonder I couldn't complete that step.
Thanks for all the input!
Rob
Old 02-14-2006, 12:20 AM
Belair62 Belair62 is offline
That top plate is what locks the steering wheel when you turn the key off...
Old 02-14-2006, 12:32 AM
PeteLeathersac's Avatar
I've found it's sometimes a good idea to disconnect the horn whenever you're working in this area. . When dicking around w/ the re &amp; re of the related parts, it's hard not to make horn ground contact a few times and the resulting honking also zap spots on the contact surfaces can be avoided. ~ Pete
Old 02-14-2006, 02:13 AM
Well I found what the deal was. I need a Camaro part so I stopped out by Ron in McHenry looked at another steering column.
What I realized is that I had taken the plate and spring out earlier. There was no snap ring holding the plate and spring. Someone had put things back together without using the snap ring.
So now where do I get a snap ring to go back on the column?
Rob
