Old 02-08-2006, 03:07 AM
jeff morocco jeff morocco is offline
Default hemi
anyone seen a hemi like this before ?
[url=http://www.freeimagehosting.net/][/url
Attachments - The Supercar Registry 189502-mailbox001.jpg 189500-mailbox003.jpg 188849-682-FRD.jpg 188847-KodakPictures-603.jpg
Old 02-08-2006, 04:11 AM
TDW TDW is offline
Default Re: hemi
I have one like that without the Ind. tag. Mine is a 1955 331 CI. Looking for a body for it now. If you get the numbers off it, there is a nice site to decode it.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 02-08-2006, 04:40 AM
BUIZILLA BUIZILLA is offline
Default Re: hemi
Back when I was an aircraft powerplant mechanic, we had several of those in Hobart drive around power units. I had to convert them all to electronic ignition, because they ate points/condensers for breakfast. BIG two barrel carbs and oil bath air cleaners too... then I converted them all to run on propane... one blew up, and I stuck a 413 in that one from a wrecked D500 Dodge truck
JH
aka - Mighty Mouse
Old 02-08-2006, 04:47 AM
Default Re: hemi
i used to work for united airlines as well as my father , and he was the garage op. manager and this was in the ground power units that started the planes. there was at least 4 of these that were sitting around for many years. this one made it back to his house.
Old 02-08-2006, 04:48 AM
Default Re: hemi
They were used in generators and industrial applications. Don't know what, if any, internal differences there are.
Old 02-08-2006, 11:06 AM
skierkaj skierkaj is offline
Default Re: hemi
well here's one . . . sorta
John "Hutch" Skierka
Old 02-08-2006, 11:09 AM
Default Re: hemi
and I know for a fact there's a 331 under the hood of this little cutie . . . '54 Desoto Firedome. 1 of about 8 original 2 door Hemi cars still surviving. Original motor is gone . . . has a '56 331 Hemi.
Old 02-08-2006, 06:10 PM
moparts moparts is offline
Default Re: hemi
I went to Rankin Tech in St Louis Mo and we had 2 of those engines running 750 K Gen. Sets. Those 2 hemi's had to be tuned to perfection to get enough out of the generators to start the 1000 hp locomotive engine at the school. The class before mine forgot to turn on the oil pump to the engine and it oversped and siezed a rod brg. It was a big inline 6 Detroit and 1200 rpm was overspeed for it. The building it was in covered a city block square and we all thought there was a earthquake when that big boy went. My class got to tear it down and I now have a rod and piston assembly out of it for my mail box stand.
Anyway back to the hemi's Buizilla is right it just about took a new set of points everytime you wanted the things to run right. I don't remember what the hp was but it wasn't very good. The one's on the gen sets always had a vibration to them that just never seemed right, don't know if it was the engine or the gen. they was turning.
20 foot 75 hp good time at the lake
Old 02-10-2006, 04:44 AM
Default Re: hemi
is it worth putting into a street rod of some sort or just clean it up and have it to look at ?
Old 02-10-2006, 07:15 AM
Belair62 Belair62 is offline
Default Re: hemi
Make another hole in that bar Jeff !!!
