Old 02-05-2006, 11:15 PM
69 Code51 Z 69 Code51 Z is offline
Default Correct Part # for 69 Camaro AM Antenna Mast
I have a mast that appearts to be a 69 Camaro AM mast - oval body - grooved top and serrated bottom with cap. However the part # on the wrapper I can't find in the assembly manual. The part # on the wrapper is 9787725 then group 9.645 . Is this correct ? Thanks Carl
Old 02-06-2006, 01:04 AM
Default Re: Correct Part # for 69 Camaro AM Antenna Mast
That looks like to early of a number for the 1969 Camaro.
I'm showing that number you have as being for a 1967 Pontiac GTO originally.
If you can wait till I get home,I can double check that.
Old 02-07-2006, 09:55 PM
That part number is indeed a Pontiac only Application.
It is not a Chevrolet part at all from what I can see.
Parts history shows it was discontinued sometime between 1976-77.
My Pontiac book description for Part #9787725:
1967 8cyl GTO-Non Telescopic Mast Front Fender-Oval w/oval tip & Bonnet bottom w/Female round nut.
I thought this was possibly also a Firebird and therefore maybe a Camaro application,but it doesn't look like that at all..
