Old 02-05-2006, 09:09 AM
Denis Denis is offline
Default Can anyone ID this fan & fan clutch?
I'd sell this if I knew what it was.
I *think" it's a '64 Corvette fan clutch with a 5-blade fan from perhaps another early sixties Vette.
Any Vette fan clutch experts here?
Old 02-05-2006, 12:12 PM
mssl72's Avatar
mssl72 mssl72 is offline
Default Re: Can anyone ID this fan & fan clutch?
Unbolt the clutch and see if there is a part number or something stamped on the front of the fan hub. The fan is the same 5 blade configuration as my car. The clutch is different.
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
Old 02-05-2006, 07:08 PM
You clutch is dated 1961. Look like it anyway.
Old 02-05-2006, 07:15 PM
Enoch Enoch is offline
Banned
If you look on the flange where it bolts to the water pump sometimes there is a date stamp like "66 D". I have seen this clutch and fan set-up on mid-year corvettes. The flat bar set-up was interchanged with the coil type clutch.
How is the clutch does it have any resistance left?
Your guess is right I've worked on original 64-67 small block cars with this set up.
Oh by the way the fan is correct too. Repro fan goes for 100-200 and they don't repro the flat blade clutch so if it's good I would say it's worth at least as much as the repro coil type cluth which goes for 175.
Hope this helps, Rich.
Old 02-05-2006, 11:56 PM
The clutch is real nice, turns like new.
Is there a place where all the NCRS 60-65 heads hang out?
Old 02-06-2006, 08:04 AM
Zedder's Avatar
Zedder Zedder is offline
Post the pics here...
http://www.ncrs.org/forum/tech.cgi
Mark
Old 02-07-2006, 12:18 PM
These #'s are stamped on the fan clutch flange. Does this mean anything to anyone?
H0971SC
