Old 02-03-2006, 04:46 AM
Default Headliner Installation
I searched but could find no topics on this. I am trying to re-install my original headliner back into my 69 Z but I am have having a hard time getting the rear portion to fit correctly with no wrinkles. Any tricks?? The front half looks great (mainly because the headliner had marks in it where the sun visor brackets mounted). Thanks for any help!
Tommy M.
Old 02-03-2006, 04:55 AM
69L78's Avatar
69L78 69L78 is offline
Default Re: Headliner Installation
I have used a heat gun to get the wrinkles out.
Old 02-03-2006, 05:48 AM
Like a hair-dryer or a stright up heat gun? Will this danage the vynal at all? Thanks
Tommy M.
Old 02-03-2006, 02:10 PM
69L78's Avatar
I have used either, but if you are not sure of yourself, I would try the hair dryer, and yes if you hold it in one spot too long, you could ruin it.....keep the the heat gun moving back and forth.
Old 02-03-2006, 06:41 PM
use close pins to hold it to the rail, then heat it... pull it.... heat it.... pull it.... not a fun job, best done in the winter so you don't sweat to death!
Old 02-03-2006, 08:10 PM
I'll try that. Thanks!
Tommy M.
Old 02-03-2006, 09:43 PM
Enoch Enoch is offline
Banned
Don't laugh but I used my Wife's "Scuncie Steamer" that she bought to remove wall paper and it worked like a charm. Also make sure the cloth liner that the rod slides trough is trimmed back far enough to let the liner to be streached to the sides without bunching up.
Rich
