Old 01-30-2006, 02:10 AM
Default 010 Block
I just aquiried a smallblock 010 4 bolt main block,looking up the 010 numbers it says a 302 or it can be a 350,how do you tell if it is a 302 block for a z28 Camaro or a 350 block!
Thanks
Bobby
Old 01-30-2006, 02:58 AM
Default Re: 010 Block
It was used in both the 302 CID & 350 CID engines.
1969 was the only year it would have been used as a 302 CID for the Z/28,so check the casting date in back & application prefix stamped on the front pad,and if there's a VIN# stamped into it too.
Old 01-30-2006, 03:02 AM
DarrenX33's Avatar
A cast date of April 69 to November 69 could be 302.
1969 Z28
1972 Corvette
Old 01-30-2006, 08:47 AM
GTO_DON GTO_DON is offline
I thought it was the crank that made it a 302
1969 GTO convert RAM AIR 4spd
1964 GTO convert survivor
Old 01-30-2006, 11:36 AM
indyjps indyjps is offline
what are the #'s on the front pad, this wil tell you if it came out of a z28
Old 01-30-2006, 10:51 PM
musclecarjohn musclecarjohn is offline
010 is the last of the '69-'70 Z/28 blocks (302-350)and was commonly the replacement or "service" block that was used.
1967 Buick Skylark GS400 Funny Car "Ingenue"...World's only Buick-powered Buick Funny Car/Aug '10 HRM featured car
'69 Z/28 Yellow/Aug '07 CHP cover car
'70 Z/28 R/S Orange/Jan '08 CHP featured car
'70 Chevelle SS454 LS-5 Red/Jan '11 CHP cover car
Old 01-30-2006, 10:59 PM
PeteLeathersac's Avatar
Sure, lay the pad numebrs out. . Any crank w/ it....and if so, is there a pie shaped piece out of the flywheel end? ~ Pete
Old 01-31-2006, 04:35 AM
The block has V1103TJZ on the pad,has J1232 on the rear of the block on top,the crank is 3941182.
Bobby
Old 01-31-2006, 04:36 AM
Ive got a 4 bolt 010 block with a f-1-1 date code on it and nothing stamped on the pad. standard bore. if anyone needs it ,let me know because I want to sell it.
Old 01-31-2006, 06:09 AM
Bobby
That's a 1973 C-10/C-20 Truck Motor.
TJZ=350/155HP 4BBl
V=Flint assembly plant
11=November,1972
03=Day
3941182=350 forged medium journal Crank 3.48" stroke
Check that J1232 casting date again?..is the 1 really a circle with a line through it?
This would make more sense:
J=October
23=day
2=1972
