Old 12-19-2005, 10:12 PM
Default 69 Camaro Driveshaft Marking??
Does anyone know what would be the correct paint markings for a 4-speed Muncie driveshaft in a 69 Camaro (396 L-78)?
Mine looked to have either Yellow or Orange stripes about 12 inches away from one end. Thanks,
Paul
Old 12-19-2005, 10:27 PM
DarrenX33's Avatar
Default Re: 69 Camaro Driveshaft Marking??
69 Z/28 M22.. This is the original paint. I can measure this when I get home if you want me to...
1969 Z28
1972 Corvette
Old 12-19-2005, 10:44 PM
Mr. T Mr. T is offline
How were these paint markings applied originally? How would one go about reproducing these?
Tony
Old 12-19-2005, 10:48 PM
Jonesy's Avatar
Jonesy Jonesy is offline
While we are at it, how about a 350/300hp 4spd?
Did these stripes just designate type of trans?
Old 12-19-2005, 10:50 PM
DarrenX33's Avatar
Paint dabbed while they were balancing...
1969 Z28
1972 Corvette
Old 12-20-2005, 02:37 AM
That mark is exactly what mine looked like. Looks like two seperate stripes in Orange applied with some type of brush while the shaft was turning.
Paul
Old 12-20-2005, 04:53 AM
Anyone think they might know if those stripes would be the same from a 69 Z28 w/ M20? Thanks everyone
Tommy M
Old 12-20-2005, 08:33 PM
MosportGreen66's Avatar
Tommy M
I would assume it a universal marking... transmission and engine displacement aside. The marking was originally for inspectors, regardless of engine size/tranny option.
Old 12-20-2005, 08:49 PM
DarrenX33's Avatar
Dan is your Z still marked? Crawl under there.
This is a good question for JohnZ...
1969 Z28
1972 Corvette
Old 12-20-2005, 09:06 PM
Mosport,
I may be speaking out of turn here as I am refering more to Chevelles but the stripes are not meant for inspectors, they are there for an easy eye reference to line workers to pull the correct shaft from the bins based on the color codes listed on the build sheet. The M-20/21 use a different tail shaft than a Turbo 400 and/or an M-22 and therefor use a different driveshaft flange. The colors are different on the shafts depending on transmission. Also in the case of Chevelles, the engine size may also make a difference since a 454 uses a different shaft than a 396 car. Just trying to clear up a possible misunderstanding.
Rick
