Old 12-04-2005, 10:41 PM
dlv4540 dlv4540 is offline
Default Big block parts and muncie tranny's
1968 two bolt block converted to a four bolt with GM caps and line bored dated K-20-7 with 323 casting number and a good steel 6223 crankshaft for $600. 1970 CTX code standard bore block dated H-22-9 with steel crankshaft 6223 for $600 with 854 casting number. 1970 L78 standard bore block with 6223 crankshaft $600 (block decked). 1967 390 oval port heads dated I-17-6 cleaned and magged with screw in studs and guides $350. 1965-66 206 oval port heads with screw in studs and guides dated E-28-5 and F-14-5 $200. 1968 069 factory aluminum high rise dated 9-27-67 $350. 1969 M22 all redone out of early camaro with GM gears $2000. 1966 muncie M21 tranny all rebuilt with GM gears $850.
Dennis Vugrinovich
