Old 11-14-2005, 12:49 AM
47Hammer's Avatar
47Hammer 47Hammer is offline
Default 69 Z 28 Distributor with an X ?
Can anyone explain the X in front of 1111480 ? the date would work for my car. Thanks!
http://cgi.ebay.com/ebaymotors/1969-CAMA...1QQcmdZViewItem
Old 11-14-2005, 01:25 AM
KENNY_PASCOE KENNY_PASCOE is offline
Default Re: 69 Z 28 Distributor with an X ?
I'VE SEEN AN X ON A 499 DISTRIBUTOR BEFORE BUT THIS IS A FIRST FOR A 480. LOOKS LEGIT.... KP
1969 CAMARO SS 396/375 VAN T SOLD
1966 CHEVELLE SS 396/375
1969 CAMARO Z/28 ORIGINAL PAINT
Old 11-14-2005, 01:31 AM
rpoz11's Avatar
rpoz11 rpoz11 is offline
With this and the XXXXX on the Trim Tag on that SS396 Dusk Blue car in another thread....could it be possible that the numbers gang holder was to be X'd out each time it was used?
I mean was the person using the tool trained to remove each set of VIN or part #'s after each hit so as to not repeat the last set of numbers? and place the X back into the tool? Or in this case, with this 480 housing, was the tool an 8 postion tool; having the X to fill the end of the spacing in the tool?
I have never seen this tool used to stamp these, whether it was for deck pad, side block, distributor housing, trans housing, etc etc....????
Old 11-14-2005, 01:46 AM
Z28DZ Z28DZ is offline
Hey check out my trim tag with the X before the interior code
Old 11-14-2005, 01:54 AM
JChlupsa JChlupsa is offline
Z28DZ???
Whats the VIN of your car if you dont mind. You can Email it to me if you like
Old 11-14-2005, 03:20 AM
It's the my 9561's tag, Jeff - N647218.
Ed
