Old 11-05-2005, 04:49 PM
gtaa9 gtaa9 is offline
Default running rough
I just bought a 68 GTO with a 400 auto.I noticed that it was running rough so I check the dwell and it was sitting just below 20 and I know that it suppost to be at 28-32.I ajusted the points to 30 and then I check the timing it was alittle past 12 degrees advanced it suppost to be at 9 degrees so I was ajusting the timimg back to 9 degrees and it wanted to die.So what I ended up doing was puting the timing back were it was and the points back were it was and it runs better but still runs alittle rough.I have'nt replaced points or spark plugs.I appreciate any and all suggestions.Thanks
Old 11-05-2005, 04:52 PM
Default Re: running rough
Try balancing the carb.with a Vacuum gauge & check the underside of your Distributor cap for corrosion.
Old 11-05-2005, 05:43 PM
How do you ajust the carb with a vacuum gauge?I normaly ajust the carb with my dwell meter and set it on rpm and ajust.
Old 11-05-2005, 06:29 PM
moparts moparts is offline
Basic rules for tuning up points ign. cars.
Always set dwell 1st. 30 deg. for any v8 gm.
Always set timing 2nd. Make sure vac advance is unpluged.
Adjust carb last.
Reason for this: dwell makes a difference in timing, and carb tune up. timing only messes with carb tune up. Adjusting carb will not make any difference in dwell or timing.
You use the vac gauge just like you would the tac. look for the best vac reading when adjusting the carb.
Do it right and you get.....
20 foot 75 hp good time at the lake
Old 11-05-2005, 11:05 PM
The vacuum hose that is connected to the dist.does it go to a vacuum port in front of the carb?When I disconnected the vacuum advance to ajust the timing it died.I'm pretty sure that its no suppost to do that.
Old 11-05-2005, 11:57 PM
TDW TDW is offline
I would put a new set of plugs, a condensor, and a new set of points in it. I would check the cap and wires also. That way I would know for sure all the parts were good.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 11-06-2005, 06:28 PM
Thanks for the information guys.
Old 11-08-2005, 01:06 AM
Where does the vacuum advance hose from the dist. go to on the carb end?Mine is connected to a port on the back or the carb right on the bottom.I think that is a constant vacuum any ideas?
Old 11-08-2005, 02:08 AM
Manifold vac. is what you want... at right front on a Q-jet I think is right...guys?
Old 11-08-2005, 07:10 AM
I would go ahead and do a general tune up,Points,condensor,plugs,cap,wires and then adjust the carb and timing.I just did a 44 mopar and all it that was wrong was a couple plug wires going bad!
Bobby Dodson
