Old 09-18-2005, 08:10 AM
Default 124379N571386 your block may be on ebay.
Check out auction.
Says 124379N371386 in the description, but I believe 3 would have to be a 5 as they started with 500001, correct?
http://cgi.ebay.com/ebaymotors/1969-DZ-3...1QQcmdZViewItem
Never know, might reunite a car with its engine.
Lynn
Old 09-18-2005, 06:32 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Default Re: 124379N571386 your block may be on ebay.
They should at least have pics of the stampings!!!
Old 09-19-2005, 07:06 AM
You would think.
Old 09-19-2005, 10:21 PM
William William is offline
A VIN of 124379N571386 [Jan '69] would not have a May 7 engine. 124379N671386 is also out of line for the engine date.
Old 09-19-2005, 11:20 PM
You are probably correct William. Mine is 124379N671122, and is an 08A car. Engine is July 2 build. Guess it is possible for a car 264 after mine to have an early May build engine, but not likely.
I have emailed the seller asking for a double check of the numbers. BTW, I have no stake in this deal, just like to see cars and engines reunited. It does happen from time to time.
Lynn
