Old 09-13-2005, 08:20 PM
rsatz28 rsatz28 is offline
Default How to? - Heat Drag Radials w/4sp-No line Lock
What is the best technique to heat drag radials up with a 4-sp without a line lock? Had street tires last year. Going to DaGrove next Friday and need to know. Thanks.
Rob
69 <font color="orange">HO</font> Z-28
Old 09-13-2005, 10:07 PM
kwhizz kwhizz is offline
Default Re: How to? - Heat Drag Radials w/4sp-No line Lock
Rob......Drive around the water box and back into it, keep the rear tires in the water and do a burnout from there, depending on the power level of the engine you might want to use 2nd gear to get the tire speed up high enough to heat the tires as you roll out of the box...
Good Luck
Ken
